Update time, last few weeks have been spent putting the nitrous back on, having the suspension alignment done, and then a trip to Santa Pod to shake everything down.
First up was to get everything pointing in the right direction, I'll do a full review of this later, as I've not driven the car on track yet:
Rear axle mounts modified, shim spacers on the sub axles to adjust camber and toe, lots more measurements taken along the way, full review after my next trackday. Thanks to Chris at CofG for his efforts, I'll no doubt sing his praises at a later date
Gas bits (bottle heater):
Keeps a constant pressure by heating the bottle, maintains ~950psi
NA vs Boost:
Santa Pod time, boost wound down to 20psi but was pinking, so backed out of each run (only managed 3) best 13.1 @ 109mph, showing power is there, but need to sort the pinking issue before next outing, I suspect aquamist isn't working.
Pics, ronald is my mates, awesome little toy!
If I can sort this issue out, I'm hoping to get some runs in on Sunday at VW Action, should be quieter then, although it's twice the cost.
Cheers
Pete
